Maxogen is like 350 quid. You won't many gains from any induction kit so I would suggest BMC CDA (about £180) with CAF routed to your fog light or lower grill
Maxogen OR you could make your own using a ph1 172 airbox and panel filter then direct a cold air feed from your lower grill into the void behind the headlight. Exactly the same as a Maxogen but not carbon.
