best place to port/polish head , best place for uprated valves ??
Hi all , i have a head that i am wanting ported and polished !! looking for somewhere that i can send of to , does anywhere do uprated valves as well , i had a quick look on the supertech website and cant see anything !! is it worth changing the valve springs , the car has jenvey itb's with mappable ecu so rev's have been upped
  HBT 172 Cup
Craig will do you the best work out their IMO.
Only need uprated valve springs if your running substantially beefier cams, i.e cat 422's
  Audi TT 225 Quattro
as said highly recommend Craig (stan*) @ ap developements, recently rebuilt my head along with port work and gas flowing etc etc. no problems at all:D
  HBT 172 Cup
i *believe* his services to fully rebuild and fully gas flow a cylinder head is now 650. Worth every penny imo (from what ive seen of when my engine was running and numerous numbers of friends who have heads done by him).
Worth the extra over other companies anyday imo.
  182
What are the advantages of this work?
My aux belt went and we find out tomorrow if its caused valve damage.If they all need replacing i might look at getting something upgraded whilst im at it!
  HBT 172 Cup
Lol open a can of worms why not! Many many (and generally poorer tuners), will gas flow heads for peak power, high valve lifts e.t.c, this can lead a piss poor engine.
From memory expect around 5% - 10% (could be wrong!) gains in flow accross pretty much the entire rev range, which will be a directly proportional increase in torque and power. It doesnt sound a lot, but it makes all the difference.
Craig will make the head bespoke to you, you tell him if you want a gas flowed head for rally race engine, or a head for a road car and he will do as per your needs. Most cheaper engine tuners will be scratching their head by now going ... "so you want a stage 1 head yeah?" :p
  2.2 bar shed.
Sabre heads. Done all the stuff for me and my brother and its flawless. Quick turnaround and 'reasonably' priced.
ap developments seem to be the guys to go for , someone who has knowledge with clio heads rather than a companie that just port/poilish's head , at least if you go to a companie that specialise in head work on clio's you will see the best gains
  Golf GTD Mk7
Yeah, I used Ric for my inlets. Great chap, knows his stuff. Not cheap mind, but the CNC setup they have their is wicked.
