Best suspension for my Cup 172?!
1
172Petey
Want to go the the next step from standard now, been looking at what other people have done an it seems like most go for the coil over option. As I am not planning on changing the set up after it has gone on as its my every day drive I wouldnt have thought I would need them?!
Want to make the handling better rather than make the look of the car more agressive.
Im just asuming that im going to need some springs with a higher spring rate and dampers with a higher rebound rate?
Advice please. :)
  BMW M4; S1000 RR
If it's just a road car, I doubt you are already on the limit on which you need tuning to make it go faster.
Otherwise I would look at those Bilsteins on Ktec. They certainly look tastey.
1
172Petey
I didnt want to go down the coil over route unless I really have to, I cant see that there is any need?!
Isnt there a set up that is much more simple yet effective such as the bilstien sprintline kit? Is that any good?
  Lionel Richie
Koni kit, and bilstein kit (both shocks and springs)
coilovers are sometimes a bit overkill, its a hell of a lot of money to spend
1
172Petey
Its the fact that coilovers will need to be set up, though I have just seen the bilstein kit on Ktec's site (didnt see them on yozza) and it sounds tempting, + - 20mm adjustment seems good and I had billies on my old saxo, they were stunning. Just an incredable amount to spend on some thing which I doubt I really need!
http://www.k-tecracing.com/show_product.asp?id=2044
Just want to make the car even better and stiffer, already bought a set of PE2's for grip, suspension next step I think?!
1
172Petey
I cant find any site that sells the sprintline bilstein kit for the renaultsport clio. Then I need to find out if that kit will fit on the CUP!
1
172Petey
I spose it is a bit changing it for changings sake, but im a mechanic an ive got itchy fingers!
New uprated springs an shocks is so appealing!
