Big brakes
  Turbo Beige
Anyone fitted a 4 pot brake kit to a 182? If so what size disc under standard wheels and what is the kit?
Looking at building my own with some EVO 8 calipers and redrilled discs from a Megane 225 but wondered what was around?
  320d
300mm are the biggest discs thatll fit behind 16" wheels thats what i have on mine
Standard disc size is 280 on the renaultsport clios
New shape Meganes are 5 stud though
  320d
Not sure about the 310mm discs paul guess it depends upon the size of the caliper then if youve got the weights on the inner rim to balance the wheel which would cut down on clearance
  Turbo Beige
You can get 310s behind 15s with the right wheel, it also depends a lot on the caliper (back face depth). I know that meganes are 5 stud, i will make a jig and then redrill and tap them.
Just wanted to know what people were using and what was avalible from who etc.
