FAO auto electricians / ICE experts...
Ive just finished putting a big stereo into my Scirocco - a JBL 80.4 four channel amp running the fronts and rears, with a JBL 300.1 monobloc running the sub. All up, puts out around 300W rms. Peak current draw is around 70 A
Got a brand new battery in there just to be on the safe side, dont know the Ah rating, but its 620 Cold Cranking Amps and 110 minute reserve capacity at 25 amps draw. So about as hefty a battery as I can fit in.
Problem is that after giving it a full charge, it only took half an hour of running the stereo fairly loud to run the battery down do badly that the wipers would barely move, and this was with the engine running as well.
Over the last couple of days Ive been charging the battery up overnight with a 4A slow charger, then putting the battery back in, running the stereo not that loud and every night I get home from work and the batterys wrecked again, the alternator light flickering on and off struggling to keep it idling.
So this is what I need help with: I think the alternator is a 90A model, does that mean it should be putting out a 90A current all the time its running? The most obvious answer to my battery emptying out after 20 minutes of loudish music is that the alternators not charging enough. Ive been to a local auto electrician but dont want to get stitched up so thats why Im asking here. What they found was that just having the blower, rear demister and headlights on sucks up 37A just for starters and the alternator is struggling to make much more than that.
Am I right in thinking its time I got the alternator overhauled or totally replaced or is it something else?
