Disconnecting battery for storage
KitsonRis
So my Clio, E34 and Z3 are not being used for the winter I need to do something to the batteries to disconnect it to stop them going flat.
I used to be able to trickle charge the E34 with a battery conditioner thing and that was ideal. Don’t have the option to do it in my new house.
The question is if I disconnect the battery and leave them out the car for a few months will that damage the battery, like what can happen when you let them go flat. As I think the Z3 battery has had it I don’t want to buy a new one now and it go bad before I get to use it in the spring and end up needing a second.
Yosemite Sam
  Whichever has fuel
I just disconnect the negative lead and leave the car as is.
Then a few days before you want to fire it up again, stick a charger on it to make sure it’s topped up.
A good battery shouldn’t go flat flat if it’s not connected to anything.
  Clio 172 + Clio200T
Exactly this.
If there is nothing draining in the car the battery will stay at high charge levels without problems if its chemically ok.
I usually do the same with my bikes to keep batteries alive during Winter.
Except when I forget and on spring I have a nice surprise 🤣
