Binning ABS and running brake lines in the car
  PH2 Clio 172
Hi guys
was woundering if anyone has done this. were planning on having no ABS in the 172 so as where at it may as well run all new brake lines with a brake bias for the rear.
has anyone got a brief overview of what needs to be donw with the Clio.
Cliff
  172 Cup
Yes i have done this on my cup, line from master cylinder into bias valve, out into cylinder for handbrake. Then run a line to the rear of the car where it connects to a flexi pipe which then runs down into a T piece on the rear beam. Out the T piece to each caliper.
Works well.
  Ph2 172
Does binning ABS offer much of a weight saving? I understand that's probably not why you've done it but just curious.
Cub.
A reasonable amount of loom came out and the weight of the pump. But it's not major weight saving. I did mine because the ABS pump get blowing fuses on track days. I didn't want ABS on track anyway really.....
