As above really- blip the throttle and i get a hissing sound from the back of the engine (sounds to be)
Only really the first 500rpm from idle (bad misfire). It also has he EML light on after fixing lamba, plugs, leads and coil pack.
If i blip enough it will eventually cut out...
Compression test being the way forward or should i look at the manifolds?
I've tested it before which came up misfire cyl3 but that was before changing the afore mentioned parts.
Advice?
Advice?
