Blocked washer jets
Clart
Cant get my jets to spray any water, Ive filled the tank up, pushed a pin down the washer jets, but nowt. What can i check next?
Are the motors ok? also try disconecting the water lines and blowing compressed air down them, worked on mine.
Check your electrical connections to the pump, which is probably attached to the water bottle, possibley a faulty earth.
Have you washed your car recently or has it been stood in anywhere damp, I had the same problem turned out that water gets down into the supposedly sealed motor and rots the connections.
I ended up having to strip it down and cleaning everything out, takes about an hour as you have to be very careful getting the body of the motor, flimsy plastic thing.
Clean it out and bung some silicon sealant around the join on the plastic body
Should be a good few years left it in it then.
P.S this does mean taking the Washer bottle out unless you have very small hands
Mine did the same.. pump but no water.
Anyway, took it apart.. swapped front for back pump.. and they both started working perfectly, haha.
