Bolt size of the lower outer front seatbelt rail?
As the title says.
Im looking to replace the lower bolt which sits on the outside of the front seats near the floor. The original seat belts have a rail which this bolt holds in place. Looking to see if anyone knows that size the bolt is as im trying to get an eyelet hole for harnesses to fit in the same hole.
Thanks in advance
Rolls
  Clio/ EscCos
If you can find an m10 harness bolt that’s a suitable length please post where you bought it from as I can only find 23mm long ones!
Mr Trailer Man
23mm should be fine.
They're usually an inch long, so 25mm...
Plenty long enough as it doesn't need to be as long as the original bolt because it isn't going through the seatbelt rail.
I'll have a look for one.
