Peugeot 306
Bolton Midnight Clubmans Road Rally 10th March 2007
Ever thought of having a go but don't have a MSA Licence, then no worries, same cost £37 either with or without a licence. By joining Bolton Le Moors Car Club you automatically can do this event.
Yep that's right you do NOT need a competition licence to do this event, so an ideal first taste of road rallies.
Details here
http://www.bolton-le-moorscarclub.co.uk/bolton_midnight_clubmans.htm
Regs & Entry Form
Half nighter
77miles for £37
Pre plot
No rough white roads
OS Map 102
Ideal taster, refresher, novice, fun event
Now the boring bits, cars must comply with the following
22.2.7. Comply with the silencing levels C 12.1.1,
E 12.17. and 5.1
Means just not be noisy, the limit is 98db a standard car won't have a problem with this.
22.4.1. Have a maximum of four forward facing beams
as well as side and indicator lights, unless further
restrictions are specified in SRs. Light pods are not
permitted. (i) A headlamp provides the main beam and
dipped beam functions. An auxiliary lamp provides a
beam other than that provided by the headlamp. A
headlamp may consist of a single reflector with a dual
filament bulb or separate reflectors each with single
filament bulbs providing the functions of main beam
and dipped beam separately which will be considered
as equivalent to a single dual filament headlamp unit.
Lamp units comprising two reflectors where one
reflector is fitted with a dual filament bulb will be
considered as a combined headlamp and auxiliary lamp.
In this instance therefore no additional auxiliary lamps
may be fitted. (ii) Auxiliary lamps using gas discharge
technology are not permitted. Gas discharge headlamp
units may not be retrofitted. (iii) Where more than four
beams are fitted as standard only four may be used
and the remainder must be rendered unusable for the
duration of the event.
Not more than 4 beams, so not a problem unless it's something like a BMW with twin headlights and you then fit a pair of spotlights, as that could be 6 beams.
22.5.3. Not use racing style numbers unless otherwise
stated in SRs.
Rally plates will be supplied (A5 size)
22.5.4. Not have any advertising except for event
sponsor decals which must be incorporated within the
rally plate.
So it doesn't look like a rally car with stickers all over it.
If you don't have a licence then you need to join Bolton Le Moors Car Club to do the event £37 total price (+insurance), if you do have one or are applying on the night then it's still £37 (+insurance).
Details here
Regs & Entry Form
Half nighter
77miles for £37
Pre plot
OS Map 102
E 12.17. and 5.1
stated in SRs.
rally plate.
