Bore honing
Chrisgti6
  MR2,TT V6,Mini x 2
Just after a quick bit of advice from any engine builders out there.
I'm just in the process of a full refresh of the engine in my R53 Mini cooper s. It's done about 110k and was leaking oil like a sieve so took the decision to take it off the road for a few months to give the whole car a refresh.
The engine is out and fully stripped, the plan is all new gaskets, bottom end bearings, new rings etc - basically a full refresh.
My current question is about the cylinder bores - there appears to be very little wear, I can still see the original honing marks.
Would I get away with just having it re honed and then using the original pistons with new std size rings - or would I be better getting it bored and going oversized with the pistons and rings etc?
I can get photos of the block if needed, it's in a box in the shed currently.
gez 172
  Defender 110
If your honing it (which I would) then I’d be going up a size and doing it properly. Too much of a risk to put standard size rings in and risk it using oil. I’m sure you’d be able to get bigger ring sizes for standard pistons?
green
  Hi comp phase 1
I’ve been looking at the parts Lohan do for the mini if you have a nice budget.
