.. where it goes under the scuttle pannel.. is that ment to be sealed.. and mine had a big gap where all the sealant has perished and water freely flows under it... is that right?
you should not see any screen glue at all so if you have loads at the bottom of the screen then they have fitted the screen with out taking the skuttle off but water dont go up
no its not sealed (at least at the drivers side) as that needs to be removed to change the pollen filter, and there was no sealent there when I did mine.
