Brak Fluid Question
Car  RenaultSport Clio 182 CUP
Hiya
Brought some Racing Brake Fluid 5.1 Dot on Ebay, but after having a good look at it, its not fully synthetic. Does this matter or do you have to use synthetic brake fluid on a Clio 182 :S .
Many Thanks
Chris
Get rid of the 5.1 its not needed you need to bleed 5.1 all the time otherwise it rusts the brakes as its hydrosopic.
I thought the higher the dot, the better, shows how much I know! So what break fluid do you recomend then as Iv just brought a goodridge brake line kit as want the breaking to be a bit better!
well in that case, ill bung the 5.1 stuff back on ebay and get some dot 4 instead. Cheers for the advice mate
