Brake calipers from other cars
Cookie
Are there any 4/6pots from other cars (Porsche, Ferrari, bigger Renaults etc) that'll fit under standard 172 wheels?
Feature in PGTI this month that has a 306 with F360 calipers fitted has inspired me :p
  Audi TT 225
Each caliper is probably worth more than the car lol ;)
Try a porsche ceramic set for 5k or something silly lol
  Lionel Richie
the ferrari calipers aren't that expensive (if you buy them from an other source)
the Porsche 996/7 6pot calipers aren't that expensive
  LY 182
Thought the porsche ones were like a 5k optional extra?
on some of the 911 models the ceramic discs are a 5k extra, certain porsche calipers arent alot to buy
dosnt always work out cheaper though using parts off other cars, did pads and discs on a ford racing puma and the customer had a bill of nearly 450 quid !
  Lionel Richie
^AP racing stuff i believe on the FRP
the carbon/carbon discs are expensive, the calipers aren't that bad
len_beach
  E92 M3,172 track car
A mate of mine has Porshce calipers on his S3. It has been through 3 sets of discs in as many weeks as it just can't help but warp them.
len_beach
has he heard of bedding them in/letting them cool down properly?
Yep. He's had no end of trouble with them.
His other motor is a 275 bhp G60 mk1 Golf which he built himself from a bare shell so he has a good idea as to what he's doing.
len_beach
As far as I'm aware. What would your best method for cooling be Freddy and I can cross reference with what he is doing now?
He loves messing about with his cars so he doesn't mind fitting new discs once a week at someone elses cost but I think he's getting a little fooked off now.
  clio 200 F4Rt
i would of thought they would be Alcon, seeing as thats what ford mainly use.
Powerstation do a Porsche 6 pot conversion for the impreza, so its do-able.
Just find the calliper, get someone to machine you the plates, if they will work with standard discs then fine, if not get a two peice disc made up, job done.
Probably best part of 600 quid for brackets and discs.
OR
Buy something like our compbrake kit, and for a fiver i will stencil any name you want under the sun onto them!
  clio 200 F4Rt
good ducting to the brakes, and depends what wheels he is using.
a nice open design would be best!
  Breaking A 172 Replica
Quick question: How do four pots differ from normal brakes calipers? I though it was just 4 pistons on each caliper as opposed to 2 but after seeing MarkA's it appears not?
Sam
  Lionel Richie
clios use a single large piston caliper (pair of) on the front
4 pot is basically using 4 pistons per caliper (all smaller than the 1 large one) to basically evenly distribute the force over the pads
  Hondata'd EP3 Type R
My friends whos dad owns Midland Ferrari told me that all he does for big brakes is get second hand Calipers off supercars, Re Furbs them and has brackets made up.
Sure he got some Brembo Maserati 6 pots for about £80 for his Golf. You can buy a refurb kit for them for cheap as cheaps.
Very trick mod that doesnt cost that much.
I'm sure some of the mechanics on here (I.E. Fred) Knows a place who will knock up a set of brackets?
  clio 200 F4Rt
Sam
standard callipers are just a large single piston, and the design allows for one side to push and the other to pull, creating a clamping force on the disc.
simple and fairly effective setup.
There's a guy with a Leon Cupra R (although I think it just has a Cupra R kit on and may not be an actual "R") with 6 pot Porsche calipers. 14.1" at the front and 12" at the back!
