Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
you need to remove the engine cover. once youve done that look at the back of the engine on the left hand side and youll see it low down. I found it hard to even see my brake fluid level when i first checked, i now shine a torch on the side of the reservoir to allow me to read the level.
If you need to top it i recomend you buy a long funnel and top it up using that. It's a right pig of a job otherwise.
Unfortunately this is the one downside to having a small car with a big engine.
thanks for your help, the reason being is that i had new discs and pads about 6 mths ago and the brakes have started to feel a bit spongy, any suggestions. thanks
rear shoes cud be on the way out, or ur rear cyclinders cud be slightly leakin an causin you to top up the fluid, try topin it up, u shud feel a difference
