Brake Kits
  182 Turbo
What is the best brake kit to buy for my clio 182 FF 16 inch wheels with a budget of £500-700 , ideally want discs, pads , calipers and brake lines, also what's the best brake fluid for the kit? Could stretch to £800 if there an extra special kit. And it's for fast road use. Thanks
  172 Ph1, Lupo GTI
Refresh the discs with some Brembos and fit some Ferodo DS2500 pads. Theres really no need to spend a fortune. You would not get value for money
-J-
  RS2'ed 172 Cup
This... I run this exact set up and it is very good. You could add Braded Lines and a fluid change as well to improve slightly more.
  182 Turbo
Standard calipers? So just change the discs to brembo HC's? And the Ds2500 pads fit in the standard calipers? Also what braided brake lines would you recommend? And the HC discs come smooth or grooved which ones?
Sorry for 20 questions lol
  Lionel Richie
grooved/drilled discs - waste of time
fancy calipers - cool, but not really needed
but if you REALLY want them Brembos etc have a look at RIKUS in the traders section
