I am stripping out my 172 2003 for a track car. I removed the dash at the weekend which involed removing the steering wheel.
Since putting the wheel back when ever I start it the esp and service light come pretty soon after. If the headlights are of and I press the brakes then then headlights come on side lights with the brake lights! Aslo if the light are turned on then the brake lights are contastly on and after a few presses the start too flicker like a strobe contastly until you press the pedal again, then continue to flicker once you let off the pedal?:banghead:
Have been reading through about pedal switches, and have fittted one a few days before I started stripping the car and all seemed fine.
Have also read about the steering angle sensor, but nothing I read says about the brake lights not working properly!
Any help or idea's would be greatly appreciated
