ABS + SERV light no ESP light
Bowz
Gents.
I have the ABS + SERV light but no ESP light on the dash.
This started where I could start the car and the lights would not be on. Until I pressed the brake pedal, even when stationary and the lights would come on.
Now, I can disconnect the battery. Reconnect the battery, turn the ignition and the lights will be there. No ESP light.
Took it for a drive and I have no ABS.
Changed brake pedal switch.
Checked brake fluid.
Checked ABS fuse.
Checked earth points.
Checked ABS rings.
All above seem fine.
RS Tuner shows 3 ABS faults but I don't have the ABS module (have ordered through Henk/fastchip).
Anyone come across this before?
Recently fitted EPAS with DCI Rack and column.
Brake discs and pads.
Aftermarket steering wheel.
