Brake Pedal/Cruise Control Switch Part Number?
  Audi TT 3.2 V6
Hi,
Does anyone have the part number for the brake switch that stops the cruise control when you brake? Mine is playing up at the min and alot of the time the cruise control isnt working so need a new one.
Thanks,
Russ
  Clio 172 Cup
the switchs are £45 each just to let you know
Blimin eck! Im sure the guy from Renault just told me they were all under or around the £20 mark!!! but didnt know which actual part I needed :(
He said there are 5 different parts or switches. I didnt actually have a clue what he was on about, hoping someone has the correct part number for the fault infested part :approve:
AK
  M240i
Have a look in the for sale section mate, a few motors being broken for spares atm failing that PM joshydee @ cliospares..
  Clio 172 Cup
my cruise control started working theother day! when pressure was applied to the lower part of the steering wheel horn bit, coupled with pressing the cruise buttons, it worked. now that i removed my airbag to check for loose wires, everything looked fine. replaced it all, and now it doesnt work at all. so it cant be the brake switch if it worked when i pressed the horn!!!
any ideas?
