Brake pedal switch?
Louis
I Park Like a C**t
Just recently my service and traction lights have been coming on. I replaced a brake switch ages ago, and also changed both abs rings around 7 months ago.
It doesn't happen all the Time, but like this morning when i lost traction the lights came on. (Icy today).
They go off when I turn the ignition off and on which makes me think it's electrical. Is this common to an abs sensor or is it likely my brake switch has broken?
Steering wheel angle sensor probably if you've changed the brake pedal switch. Mine does it every time I get in it, which is a good thing as the TC/ASR on the 182 is the worst safety device on a car I've ever experienced. I find it dangerous when really pushing one.
Louis
I Park Like a C**t
It was changed quite a while back. I might get another just in case. They're cheap enough.
Then I'll go around all the abs sensors and give them a clean. Can you replace the steering wheel angle sensor?
Louis
I Park Like a C**t
I've reserved a Febi brake switch from ecp that I'll go collect after work.
I also have some hubs that im having bearings pressed into and these have some abs sensors on them. I've no idea on whether they work or not but I'll be able to tell when I fit them.
