172 cup, Impreza P1
Thought I'd get some data on brake disc temperatures at a track day as was at yesterday to see how much difference ducts actually make.
I used an infrared laser thermometer and checked as soon as I could when I came off after 2 cool down laps after around 20 fast laps.
Car is a 172 cup with standard calipers, pagid rs4 pads (front) ferodo ds2500 (rear), brembo max discs (front) standard rear discs and motul pbf600 fluid.
Front brake discs = 392degC (R) and 394degC (L)
Rear brake discs = 41degC (R) and 39degC (L)
Also checked my mates M3 CSL with AP 6 pots on the front and 4 pots on the rear.
Front = 395degC (both)
Rear = 265degC (both)
My question is, is the front brake temp normal or high/low compared to anyone else? Also, I know the rear brakes on the cup do very little but the temp on the discs show that they do pretty much nothing at all, is this normal?
I will be fitting brake cooling ducts before my next outing so will be able to compare before and after results but would be interested to know what you guys get.
Cheers,
Steven
Cheers,
Steven
