hey, i have a 05 dynamique and was looking at getting drilled and grooved disks and uprated pads, has anyone done this on a 1.2 16v?? where is the best place to get them?? and do any of you have any pics??
cheers
craig
Forget any fancy disk stock FDB645 are fine for 99.9% of use including treack wprk if you want any more ds2500's are £60 vs £17 for the halfords FDB845 (stock setup) just bleed the brakes and use some good fluid thats all you need.
If you want get the fancy looking Ktec big brake kit its no better and could crack as its a fancy drilled sisk (although none seem to) or if you want over kill get the 4 pots from Yozzasport but even with 180hp I cannot fade then on hard track work even slightly so with 75hp its wasted.
