Brake warning
Car  DCi
I was driving last night and my STOP and handbrake lights came on signaling a low level of brake fluid - they only came on when I was going fast round corners - do I need to check my brakes or was it just the force of going round a corner moving the fluid?
your brake pads are worn, always happens to most sports, both ny 172 and 182 have done the above. Your fluid drops enough to go below the level sensor, when you change the pads. fluid is pushed back into the res because theres more meat on the pads .
