breather pipe from ebow??
Car  clio 172 mk2
Hi people!!!
does any know what the breather pipe coming of the ebow is meant to be connected to??????
thanks martin
It's a crankcase breather which lets fumes back into the induction tract...should conect into the rocker cover underneath the coilpack to the rear of the engine.
No it doesn't it connects to the idle control valve. The crank breather connects to the bottom of the throttle body.
only on the phase 1 172, the elbow joins to the ISCV and the breather pipe attatches to the bottom of the throttle body.
On the phase 2, the elbow is the crankcase breather.
Yep, thanks for confirming that Ben...I also actually bothered to read the car description below his username:D
