Greeny.
440i + 182
You need to do a BT line test here, you can see what the IP profile is of your line, if your synced at 8128kbps you likely to get up to around 7-7.5mbit max d/l transfer. If your test results from the BT test is lower than what your getting on any other speed test this one for instance then your ISP has probably over subscribed its pipes, ive had this previously at peek times with my last 2 ISP's where I only received around 2mbit when I was synced at 8mbit with an IP profile of 8mbit.
