Broken Radiator
Clart
I filled my car up with water on friday but its used it all up and the tank is almost dry.
Whats causing this - dont think its leaking - is the radiator fooked?
Please help me!
if there is nothin leakin in ur coolant system, i can only assume you have a cracked head or somethin, check your oil filler cap and post what colour the stuff inside it is......is it milky ?
hmmm, if its low at the moment fill it up and try an find some leaks
never run a 16v without enough coolant/water in it, they run very hot anywayz
if you fully drained and flushed the engine, it will take a few runs ot get all the air out. Just keep topping it up, but should take no more than 3 attempts.....dont thash it though!!!
