Bucketts and harness's
  none :(
looking at getting some buckets for the fronts and also some harnesses, but i need my rear seats so is there anywhere else i can mount the harnesses or do i just stick to seatbelts
thanx in advance
even with sliding subframes you will be hard pressed to get anyone in the back with buckets. You need to either go for recliners instead or resign yourself to not having any rear seats.
  none :(
so is there anywhere else i cam mount harnessess if i need the rear seats or will i have to settle for just the seat belts.;
thanks for the advice
you could use a harness on the drivers side so only lose one rear seat and keep the standard belt on the passengers side. As for mounting them then will always interfere with the rear seats im afraid.
No problem, dont ask you dont know. If you want access to all the back seats you will need to stick with standard belts im afraid.
