buzzy noise
hi, when im on the motorway, at arounf 70mph onwards (under4000rpm) in 5th gear, im getting a buzzy feeling to the engine in feel and also in sound, I dont think its the 4k rattle, any suggestions...
Rich-D
  E90 LCI 330d
Probably something vibrating... most likely a heatshield...
Have a quick look underneath and have a little tap/rattle at all the heatshields at the front, youll probably find one of them is either a bit loose and/or too close to the chassis or exhaust/downpipe. Another thing is the wires for the lambda sensors can be touching the heatshields and vibrating.
Have had this on mine!
Speed sensitive wasps in a tin under the passenger seat? ;o)
Does it happen when you nail it, or just when you are cruising?
I get a vibration just over 2,000 RPM which is definately the heat shield, and also round sharp left hand bends - if I take them at lift off over steer speed it makes a hell of a noise!!! Probably because its a tight fit under there and if things arent in exactly the right place...they rub. Probably needs bending slightly.
There have been lots of instances with clios with heat shield issues - its your most likely cause.
  FN2 Type R +MK6 Golf
common prob .Had mine done last year.If you can do it yourself youll save a day at the garage...
Regards,ian
Quote: Originally posted by Dno194 on 17 February 2004
Speed sensitive wasps in a tin under the passenger seat? ;o)Does it happen when you nail it, or just when you are cruising?
its when im accellerating, when I lift off the feeling goes....
