What do people do when fitting a CAF on the standard air box for 172 as they have 2 air feeds. Should i block one off and just run the one i am running from my fog light?
Pics would be wicked
Dont block any off as more air the better. remove the one which is attached to the accoustic valve, remove the valve and one horn. then you should be able to fit about 70-80 mm caf no prob to the front grill or fog. I tried fitting a 102mm caf for my V6 airbox and had now chance with somthing that big.
