calling 182 owners
I've had that on mine, masses of condensation on the rear screen when you hit 5K+ rpm. It's now massively reduced since fitting the prospeed exhaust, so I assume it's just blowing out all the condensation/crap that gathers in the backboxes (which on the standard system are huge!)...
That's my theory anyway...
Andy182Cup said:
I thought that was just a side effect of the VVT kicking in.
VVt has nothing to do with the kicks in power. VVT switches on above 1.65k and off at 6.5k under certian conditions its tha cams fueling and changing of mapping from open to closed loop which makes the power kick.
I get exactly the same thing, and after some hard acceleration usually wipe the rear screen so I can see back out of it. I just assumed it was moisture condensing on the rear screen after being emitted from the exhaust. And thats what I still think it is. Don't think it's a problem.
Yeah think this i quite normal, if the car is used for lots of short journeys you will notice it even more. On cold days it makes it alot more noticeable.
yea just moisture when we got them when there new in our dealership went we take them out there is loads of mositure that comes out of the exhaust so much some i covered about 2 lanes of the local dual carrageway in it
