cam belt questions
  Renault clio RSi 1.6 16v
Hello,
Where is the cam belt located on a 2001 16v 1.6 mk2 ph1?
Is it visable for inspection without removing anything?
I can see a belt attached to the alternator on the lh side of the bay and next to it (what I think is the water pump) has another larger belt attached, is this the cambelt? Any photo's with a finger pointing to the cam belt would be a great help as I dont have a manual.
How can you tell the cambelt is in good condition / just been replaced?
It on the driver side of the engine on the end under a cover.
Its not realy visibale unless you remove the cover.
The belt whoch is visiable is the AUX belt and power the alternator etc.
I took the car in today for a 72k service (non renault) and it was changed, just wanted to check it out.
It seemed like a lot of money to spend when you cant see the work that has been done!
