Hi all, I've recently renewed my membership of CS, after a few years away from owning a Renault and having just bought a 182 Trophy. I noticed the group buy on cam timing tools (which hasn't gone anywhere yet) and I'd possibly be interested in joining the group buy for the group N timing tool. I just have a few questions first before posting in the group buy thread and committing to taking a set of tools, which I hope someone maybe able to help with.
So I understand that the 172 group N timing advances the intake cam and retards the exhaust cam for more overlap, and it makes sense to me that this would directionally improve performance. I've seen figures of 6 degrees intake advance mentioned, and 4 degrees exhaust r****d. Presumably this is crank degrees rather than cam degrees? Can anyone confirm if this is correct?
I also read that the Clio 172 Ph2 and 182 FBW are very sensitive to overlap due to manifold pressure fluctuations, causing the engine to stall at idle, and this is why catcams 421s don't work well with the standard ECU. Presumably this is the reason why the group N cam timing needs to be combined with a remap that increases idle speed?
Has anyone got any experience of running more overlap on a 182 with the standard cams (and the appropriate remap) either group N timing or something custom, and does it provide a worthwhile performance benefit over standard timing?
Any advice is greatly appreciated!
Cheers, Simon
Cheers, Simon
