Cambelt/dephaser recommendations
  Clio 182
Put it off long enough i’m getting twitchy as its sounding more and more like a diesel!
Any reccomendations for a place to buy the kit? Does the water pump need doing at the same time?
Have been quoted £200 by a mechanic at my brothers work to get it done. - he has done two or three 1*2’s before with the right timing tools ect.
If anyone knows of anyone else near the Worcester area let me know please!
Matt W
  Volvo XC60 T8
£200 😂
Renault Parts Direct are offering good discounts at the moment on the cambelt & dephaser kits. I just purchased cambelt kit, dephaser pulley, aux belt kit and water pump from them and was £200 less than my local dealer!
  Ford Puma, Focus
Had mine done by a couple of mechanics/enthusiasts for £550 all in. All genuine belts, water pump, dephaser, filter and oil from RPD. Cost was £350 in parts.
DrR
  VW Golf GTD
I think Steve M read the £200 as labour only, not including parts, not sure though as I’ve not read it properly.
chris blue
  clio rs 220 trophy
good price- rentech places are £750, labour 1 day, cam & aux belts, water pump, dephaser and coolant inc of vat
Clio_fool
Just out of intrest, does anyone else make the dephaser pulley? One day I presume Renault will discontinue them and will we all be fooked then?
  Clio 182
Does anyone have the full list of part numbers needed for a full cambelt ect refresh?
Would be annoying to miss something out haha
jonno_c
  VW T6
Anyone know a decent garage in the Surrey area for this?
My sister keeps putting it off on the BG (due Nov 17 as had last been done 5 years ago), and if she makes it go bang, I may even shed a tear.
She said a mechanic they know, is going to check "electronically" when it needs doing? Is he winding her up or what?
  A special one.
You also need to replace the crank bolt and you can also buy a cam pulley fitting kit which comprises of dephaser bolt and plug, exhaust cam nut and both oil seals.
  PH2 172
These were the correct numbers in 2014, some may have been superseded.
  Clio Renault Sport
I have replaced the dephaser, timing belt and water pump on a 172 and would just make the following observations: -
I had not done one before, but took well over the 6 hours that the specialists can do the job in. Its really not difficult, but access is really limited.
As for parts, personally, as these components are so important to the performance and life of your engine, would definitely only fit genuine parts (circa £250 with pump) and you must replace water-pump at same time, for following reasons. If you do this job you will realise that getting to the water pump is easy when you doing the belt, but if you had to replace the pump separately it would replicate a lot of the work (belt off etc). Secondly, if the pump fails which is slightly more likely with a new belt (and extra tension) it could cause the new belt to be damaged, jump and even damage your engine. If you look at the routing of the belt, the water-pump provides essential tension to the belt. Lastly, the days on the existing pump will most likely be ticking. If it starts to leak it could cause the engine to overheat.
Finally, if you understand how the dephaser works (via engine oil pressure) it is worth stating that regular servicing and as importantly use of the correct grade oil is vital to the longevity of the new dephaser. It will pay dividends with these fantastic engines if you service regularly with the correct grade oil.
I hope this helps you to make up your mind, but to me, £200 for labour appears good value, if the person knows what they are doing.
  Clio 182
I service it every 6 months or about 5000 miles with castrol 5-40 race try and keep on to of maintance where i can! Thanks for the help gents!
  Z34 370z Nismo
I'm sorry to bump this but this sounds interesting. Mines making some lovely noises. It really needs doing Its been recommend I go to twotecs in Dartford.
I've done a cam belt with help of a mech mate on my 1.2 but the 182 seems more daunting. In all honesty how difficult is it? I know I can get kits. So does that mean it comes with everything you need? Bar like oil and water pump? Will I have to change oil again? After ive only just done it 2 months back?
  Clio Renault Sport
Hi can only say use a quality/genuine kit with dephaser pulley and in my opinion you must replace water pump. It would be false economy not to as it forms part of the tensioning system and if it failed would require all same work to be done again, even if it didn't wreck your engine. £200 sounds very good to me
  Z34 370z Nismo
Doing mine next weekend weather permitting.
Idk why its posted twice one without quote one with
  Ph2 172, 106 Rallye
You need the timing tool which is what stops most people as the genuine ones are quite dear.
Ps: Blegh.
R3k1355
Yea the timing tool is pretty expensive, you can only buy the genuine one because the pattern-part is useless and puts the timing out.
If you're going to sell it on, having proof the belts were done by a known specialist is a big plus point.
