i've been through this about a million times but here goes!
lets start with an engine that is timed up perfectly from factory, when i say perfectly you can only use maximum of 3 finger from 1 hand to fit the horseshoe - anymore than that the the timing IS NOT right
now you replace the cambelt WITHOUT undoing the inlet/exhaust pullies, like a lot of engines (we shall call it THE TIPPEX WAY)
replace the belt, tension it up - surprise, the timing tool doesn't fit
WHY???
because when you fit a new belt and tension it you are tensioning the belt between the exhaust pulley and the crank ONLY, the rest of the belt run won't be 100% tight, you spin it over, the belt tension equalises - hey presto the timing is out
Hence why you change the belt using the correct method of undoing the pullies, fitting the belt, spinning the whole lot backwards to equalise the belt tension, then tighten it all up
I'll do a video sometime showing what happens
WHY???
