cambelt
Ive got the camshaft locking jig and the crackshaft locking pin. I've also got a universal snap-on pulley locking tool, should do the job?
well the renault cam pulley tool is a bit odd i found at first, as its still possible to move the pulleys even when you've cranked the locking tool up tight
is the pulley locking tool to stop the system 'flexing' as you tighten it up?
how do you avoid that when tightening the crankshaft pulley?
I'm failing to see how slackening everything can be of any advantage? :S Is it a quicker/easier method or something?
Once the tensioning of procedure 2 (no slacken method) is complete, and the engine has been turned over a good few times, if everything lines up correctly, then surely everything is fine?
anyone got the part numbers for the pulley seals then? I'd like to have them just incase I do the 'slacken ervything' method :) do GSF/ECP sell these or is it a reno only part?
