What tyres?
If its RSR then I reckon pretty much as much camber as you can get if you intend to use them hard on track.
whys this?
I will be getting some RSR's soon and wondering what camber to run (mainly track use) but needs to be driven to tracks but don't want the tyres to wear too quickly on inside edges.
what is the max camber that you can get with camber bolts?
Max on camber bolts varies, so cant answer that for your specific car.
The RSR on the clios seem to really work the outside edge, so you need loads of camber to stop that.
Its for a 182 track car
172 cup. I have had nearly 5 degrees both sides on my car with the camber bolts in the top hole.
thats insane!
And I still used to wear the outsides of RS-R's with sportlines fitted.
How do they fare on stiffer spring rates Morgan? Aren't sportlines really soft?
