CAMBER Input Needed
Car  Was a Clio 1.8 16v
My Fiesta has its camber out of line. The front 2 wheels need straightening.
Any1 know roughly how much this will cost? Does the tracking need re-doing afterwards?
Hows it straightened?
Who can do it, etc?
Thanx, Mikey.
If the cars been kerbed or had a front/side impact the car will need to be jigged to check the position of the suspension mounting points. This will probably have to be done by an accident repair co or by a Ford dealer. If the suspension points are OK then the control arms/struts/bushes etc will need checked and replaced. There is normally no adjustments for camber. Whilst their at it the tracking should be done also. Hope this helps!
i think fiestas have a bit of camber adjusment on the hub to strut mounting bolts
take it too a bodyshop they should have camber gauges to re-set it and get it tracked agen afterwards
adi
