Camber Shim Question
Oxyuris
  Clio 172
I've not had to ask many questions as I've been able to find pretty much all the answers before, however I couldn't find anything relating to this. So the last time I took the car (Ph2 172) to have the alignment done it had an unequal amount of rear camber. -2.18 left and -1.17 right. Everything else seemed to be ok, apart from needing more front camber, so bolts have been purchased and I'll head back again for adjustment.
The question is: If I were to fit a 1 degree camber shim just to the right rear this would fix this, right? Or could it cause other issues?
I know the correct fix would probably be a replacement beam as it's clearly had a whack at some point but there are other more pressing matters to be spending (both time and money) on at the moment so this appears to be a fairly simple fix for the time being... or is it?
