Cams without aftermarket management
Nafoff
i don't want to know how much it will cost etc, or what i SHOULd do with regards to management
i just want to know if i can run ok for a little while on catcam 428's with the standard management....???
It'll run fine on the standard ECU if its mapped, you dont need to go aftermarket to get the car to run right on the 428's as they're relatively mild. It'll run without a map on the standard ecu but like Danny says, dont rape it.
