£££££'s lol gunna be smooth tho mateWant to lower mine, maybe an exhaust, induction kit, window tints? how much did the alloys cost u?
But the newer one has a new induction system which means that you can only get a filter & adapter kit from K-tec - that will set you back £100 ish, ooh and the exhaust system is different- a pre 2004 model's exhaust & filter will not fit a post 2004- don't ask me why they changed it - they just did!
WHat would you want to know yo use the AUX belt to power it wire up some sort of filter for it then run the air through a intercooler if your running any decient boost then plub it to the throttle body. Then either get a stand alone ECU or get the stock one remapped or run an SMT6/7 to run the extra fuel/injection etc. You'd need to change the injecotrs or run a 5th for fueling.aledgedly you could fit an eaton supercharger from a mini cooper s on it- although no-one has told me anything more about this- other than it can be done!
There a few springs PI seem to lower the most.whats springs would i need to lower it 60mm???
