Can any1 help!
  05 Renault Clio Extreme 4
iv got a 55 reg 1.2 clio extreme 4 done bout 17-18k recently developed some intermittant start up problems. seems 2 b more often wen its cold and possibly wet n rainy.
i had the battery checkd and it was in good workin order but that seemed 2 b the case anyway as it turns the engine over but jus wont start.
2 get it goin iv found that bump starting it works so dont kno if this dus something the battery pwer cant. but it has happened in few different places with car on flat and pointing down hill.
its stil under warrenty but dealerships around wher i live (stoke) rnt very good. (one dropped engine on cousins micra nerly rote it off! other serviced my clio bout 500 miles ago and i had told them about fault and its stil happening)
just wondered if any1 els had experienced similar problems?
  clio 182 FF
im sure I had that prob years ago when I had my cliosport I think it was my relay fuse that was fcuked check your starter relay next to the battery it's quite a chunky fuse
not sure which fuse u mean m8 ther are about 4 big chunky fuses and other smaller ones aswel. and cos under the bonnent no word of them in user manual, only ones inside car explained.
