Did you notice any performance difference? Ive got both but not bin bothered to try the difference properly yet ;p
Please can you datalog on the RS tuner and for a given RPM (lets say 5Krpm) look at the following values in particular:
Throttle angle
Ignition timing
Fuel injector duty cycle
(i cant remember the exact names in the rs tuner, but should be obvious enough)
timing and fuelling can have a pretty marked effect on exhaust noise, but not normally on induction unless its a massive difference.
No time at all, an instantaneous reading is fine.
Under full load, so its at the time you actually hear the noise difference.
Just do a log, then click to the same point on both logs, and screenshot with those parameters on.
Engine speed | Fuel trim (offset) | Fuel trim (short term) | Fuel trim gain (long term) | Ignition advance | Injection duty cycle | Injection time | Knock correction slow | Knock signal (average) | O2 front oxygen sensor voltage | O2 rear oxygen sensor voltage | Throttle position | Vehicle speed |
RON98 Map | ||||||||||||
2.2K RMP | 128 | 159 | 128 | 18 | 22.25 | 11.99 | 0 | 33 | 849.1 | 488 | 78.72 | 57 |
2.5K RPM | 128 | 160 | 128 | 18 | 25.22 | 12.16 | 0 | 31 | 839.4 | 497.8 | 78.72 | 63 |
3K RPM | 128 | 160 | 128 | 19.5 | 34.34 | 13.8 | 0 | 33 | 868.6 | 527 | 78.72 | 76 |
3.5K RPM | 128 | 168 | 128 | 24.75 | 39.63 | 13.63 | 0 | 32 | 907.7 | 585.6 | 78.72 | 89 |
P&B Map | ||||||||||||
2.2K RMP | 128 | 160 | 128 | 17.25 | 21.18 | 11.52 | 0 | 34 | 868.6 | 429.44 | 78.72 | 57 |
2.5K RPM | 128 | 160 | 128 | 16.5 | 24.88 | 11.99 | 0 | 30 | 849.12 | 429.44 | 78.72 | 63 |
3K RPM | 128 | 160 | 128 | 18.75 | 34.22 | 13.77 | 0 | 32 | 888.16 | 448.96 | 78.72 | 76 |
3.5K RPM | 128 | 171 | 128 | 23.63 | 39.85 | 13.65 | 0 | 35 | 917.44 | 478.24 | 78.72 | 89 |
