Can i bridge my old amp?
Car  none :(
Hey I have a fusion ENAM3002 i got a while ago and was wondering whether or not it was internally bridged, i can't find much on google saying if it is or not and i don't have a voltmeter to test it out :(
Just wondering if anyone else has played around with one of these and can help? Thanks
Can def be bridged. Just keep the gain down. Rem gain aint a volume control!!!
haha yes i know...infact i am sorting that out tonight, might let the neighbours start to sleep...then wake them all up...b******s...
Anyway does the wire i use to bridge matter? i was going to use a standard piece of 'Remote connection' wire but thinking about it, it is pretty damn thin!
or should i go for something thicker...like one of the 2 that go to the sub (sorry i don't know the names :o just where they go!)
you don't need any wire you just connect your sub to the terminals marked bridge (usually the + of the left channel and the - of the right channel iirc)
Done that, but do I not need to connect the (-) of left channel and (+) of the right channel?
so if labelled the connections:
'A'=Left (+) 'B'=Left (-) 'C'=Right (+) 'D'=Right(-)
'A' and 'D' would go to the Sub and 'B' and 'C' would be joined with a piece of wire?
Sorry if this is completely wrong, just what i have been reading...Thanks for all your help so far!
no other pieces of wire are needed
also make sure your sub is 4 ohms as any lower will cook or throw your amp in protect
