Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Having wetflated down primer, is a wipe over with white spirit going to be alright before painting? Will it affect the paint adhesion? I'm out of panel wipe
what primer did you use if it is aerosol then i wouldnt use white spirits as it might take all the primer off and like you sa i think it contains oils. again i would use soapy water but it will only clean off water based stains but not solvent based stains and silicons which will give you no end of troubles so you would need to use a solvent based cleaner too. the tac rag is a must as well.
