If you had the bonnet open already the bonnet sensor won't be active I wouldn't have thought.
Try setting the alarm with the sensor pressed down to fool the system and then release the sensor to be able to the test the alarm. Otherwise blip the car to lock it and then open the car door with the key works.
You do have an alarm don't you ie a flashing light down by the gearstick and two sensor on the dorr pillars don't you?
Import don't have alarms fitted as standard only Uk spec cars your might be an import.
