car back after new clutch cable :(
cable snapped on sunday and ive now had it replaced with a renault cable, but my car will hardly go into reverse and every gear grinds like fuk, what can be wrong the guy who done it is being a complete d!ck and is hitting me with some crap about needing a new pedal now, which is nonsense, its as if i need to get the pedal down that little bit further to get into into gear smoothly, but its to the floor and it grinds into all gears except 5th, what is the most probable reason for this, thanks
  172 Cup, V6 255, Williams
Tiger,
Make sure the cable is routed correctly.
If it is then the guy who did it is not a dick and your pedal (complete with self adjusting mechanism) needs replacing.
Paul
he mentioned something about the self adjusting mechanism, what is this, and how much is it to replace this and the pedal? roughly? thanks
  Mazda MX5 1.8
i had to drive mine for about 3 days after i had my clutch cable changed until it would feel normal.... now its the same as ever (pretty heavy) but its always been like that - since new apparently
Mine had a new clutch back in may and the new pedal assembly cost £36 including VAT!
Hopethis helps fella!!
its a little green(IIRC) adjuster that tensions the cable
yes maybe give it a day or 2 to see if it settles, but otherwise sit in the rear seat behind the drivers seat, then turn round so ur facing the rear window, then thro urself over the front seat head first into the footwell. Then look up, hey presto green adjuster thingy!
  Mazda MX5 1.8
"sit in the rear seat behind the drivers seat, then turn round so ur facing the rear window, then thro urself over the front seat head first into the footwell. Then look up, hey presto green adjuster thingy!"
rofl!!!! telling it how it is! :eek:)
  172 cup,s2 rs turbo
the adjustment is done by a ratchet on the pedal.the green thing is just a stoppa.Is it a gen renault cable(ive had non gen cables do this to me before)
LMAO, lol, yep it is a gen renault one, i picked it up myself, ill give it a few days, cheers folks ;)
  172 exclusive no 172
what you can do is take out the green platic stop and press the peddle once when it is out .. put the stop back in and hey presto no more crunching.....
if you find after doing this that it is harder to engage the gears, go down under the dash again, release the tension on the mechanism the when the cable is loose pump the clutch gain and it will take up the slack...
whil under there make sure that the gromet that comes thropugh the bulkhead behind the clutch is correctly situated and in place..
this worked after my last clutch cable....
what he said ^^^ that will resolve your problem.
is this green thing easy to get out, i had a look earlier and the thing looks pretty solid? and whats the best position to get into to actually get into the fukcer!? lol
