Hey guys,
My car won't start, I'll turn the key and the engine will turn over, but isn't starting. It will almost start on the first attempt and then die and won't restart, will just turn over and over. Up until 2 days ago it would start first time ,all the time.
I managed after about 15 minutes of trying to get it to start, but once it was turned off again, I faced the same problem. Battery and plugs all checked. Taken the TDC sensor off and gived the contact a clean, although i understand if it is the TDC sensor i will need a new one.
Any suggestions?
Thank you.
Any suggestions?
Thank you.
