F4R'd ITB'd '92 cup racer
right in my never ending quest to get my hybrid runnning its time to put your ideas forward, heres what i know.......
originally had this problem from the start, not getting voltage to the coil pack, basically the fuel pump relay (that also controls the coil feed) doesnt click in under cranking. i get it momentarily on ignition as it primes the fuel lines, then the relay clicks out again, then under cranking it doesnt click back in.
a few weeks back i managed to get it running, didnt really do anything different to it to what i've already been doing, just all of a sudden i had voltage at the coil under cranking and it fired into life. then i tried to tidy the wiring up coming out of the relay and ever since then ive had the same problem again, no voltage at the coil
i can bypass the relay all together and get a constant feed from the battery so that the fuel pump runs and the coil has voltage, but again it still doesnt fire up.
i am now thinking that because the ecu isnt signalling the relay to close it wont then trigger spark or injectors. the fuel pump relay control is a thin orange wire coming out of the ecu, is there any way i can fool it into triggering? is this possibly an immobiliser issue? why would it all of a sudden decide to work? the ecu is fitted with an emulator and has been tested a while back on another car. could it be my bodged wiring coming out of the relay that is causing this somehow?
any help at all is appreciated
