CAR REVING 2 HIGH HELP!!
Car  clio sport 172 cup
my car today has been on 3000 revs wen i started the car ive cleaned the throttle bodie and all pipes are on i also did abit inlet mathing on the top inlet could this be it . but also noticed my rocker cover breather has snaped could it be this or the inlet ? IF ROCKER COVER BREATHER where can i get 1 frm ? cheers ppl
probably the egg shaped breather seal under the plenum
also does this if the throttle body is not connected correctly (electical plug)
maybe inlet seal (gasket).
get some break cleaner and spray little amounts near the joins, if it stutters etc then there is your leak.
Andy
hi thanks very much for the help mate .. waiting for a part 2mz so i will try this and see what happens :)
